02 dodge trouble
Old Oct 16, 2009 | 12:28 AM
12vcummins96's Avatar
Default 02 dodge trouble
my friends dodge well lets start by saying he just replaced the ip lift pump ecm tps altenator he has an edge juice w/attitude the truck willl start and run but will not rev past 1000rpms no guages are working and the altenator is not charging any ideas please let me know he is tired of putting money in it
Old Oct 16, 2009 | 12:46 AM
wildbill's Avatar
Any codes??
Old Oct 16, 2009 | 02:24 AM
mishkaya's Avatar
Don't know for sure, but it sounds to me like either a ground issue, or a bad PCM. I would start with cleaning all the grounds.
Old Oct 16, 2009 | 04:15 AM
coyropin's Avatar
start with the basics check batterys see what the cold cranking amps are make sure the wire pos wire is good for the crossover check your disterbution box is good make sure all the fuses are good clean your ground like mishaya said on the engine and frame.
Old Oct 16, 2009 | 07:43 PM
well thank you for all the help it turned out being a bad bcm and ecm
Old Oct 16, 2009 | 08:23 PM
dustys24valve's Avatar
Old Oct 16, 2009 | 08:25 PM
mysterync's Avatar
You mean bad PCM?
Old Oct 19, 2009 | 09:19 PM
wildbill's Avatar
Updates??
Old Oct 23, 2009 | 10:47 PM
wildbill's Avatar
Closing thread due to inactivity. Thread starter can reopen.
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
Oct 24, 2014 02:50 PM
