Sun Coast Loc-Up Controller
Old Oct 15, 2009 | 12:17 PM
RSWORDS's Avatar
Default Sun Coast Loc-Up Controller
I'm doing a 47RH swap into my 89 Cummins this winter. Instead of using switches and what not to control OD and TC Lock-up I was wondering if this would work.
Sun Coast Converters Diesel Transmissions, Fort Walton Beach FL
The ony problems I see are that I dont have a VSS or a TPS. Will this work as a stand alone controller in my application?
Old Oct 15, 2009 | 12:54 PM
12vcummins96's Avatar
no the lock up controler is not a stand alone but the tcm2000 is check into that
Old Oct 15, 2009 | 01:06 PM
RSWORDS's Avatar
The TCM-2000 is for teh 47RE's
How does the 47RH put out its speed signal? Wire or cable?
Old Oct 15, 2009 | 01:12 PM
could be either
depending on the year
Last edited by 12vcummins96; Oct 15, 2009 at 01:12 PM. Reason: Automerged Doublepost
Old Oct 15, 2009 | 01:30 PM
stkdram55's Avatar
why dont you just go to a 5 spd, isnt all its used for is pulling??
Old Oct 15, 2009 | 01:45 PM
Diesel Dummy's Avatar
you can tap into the speed sensor on the back of the t case, it uses speed to lockup and shift the 3rd to 4th, thats what i was gonna use on my 47rh. It will work fine, just make sure you get the race version, that controls 3-4th shift.
DD
Old Oct 15, 2009 | 03:46 PM
RSWORDS's Avatar
I do a little street racing with it too. That and Steph does not want a 5-speed truck.
DD
Using a NP205 case.
Old Nov 14, 2009 | 05:07 AM
6btsmoker's Avatar
If it is a 47RH,it has a mechanical govenor.The only elec shift is the TCC lock up and OD.The speed signal is from the gear driven VSS to the TCM.The TCM then commands the TCC lock up.
Old Nov 14, 2009 | 05:36 AM
monster12valve's Avatar
learning
Old Nov 14, 2009 | 09:23 AM
DB Admin's Avatar
Banned
hey bobby , a friend of mine has a brand new BD Power locker you could get it for dirt cheap david.reed@bayerbms.com he dont have the truck anymore and the part is just sitting there , this is where i got the Edge Juice w/ Attitude for $200
