weight of a 4bt
Old Oct 12, 2009 | 08:28 PM
TBD's Avatar
TBD
Default weight of a 4bt
what does a 4bt cummins wiegh?
Old Oct 12, 2009 | 10:07 PM
dragogt's Avatar
IIRC; 650lbs or so, about the same as a BB gas give or take..
Old Oct 15, 2009 | 01:08 PM
slorocco's Avatar
I think it's closer to 800, according to the Cummins literature.
Old Oct 15, 2009 | 01:18 PM
12vcummins96's Avatar
the 6bt wieghs 750 so probably 500 give or take
Old Oct 15, 2009 | 03:20 PM
scarecrow's Avatar
i copied this from another site....
I contacted Cummins for more information on the 4BT and was told that many commercial customers and independent shops have used this Cummins engine. The 4BT 3.9 engine is rated at 120+ hp @ 2500 rpm with peak torque of 327 lb-ft @ 1700 rpm. The engine weighs 570 pounds (dry). The 4BT 3.9 engine dimensions are...:
Total height: 30.6 inches
Total length: 30.1 inches
Total width: 22.9 inches
Old Oct 15, 2009 | 05:39 PM
millco's Avatar
I always thought I had read the 6BT was around 1300LB without accessories......
Old Oct 15, 2009 | 07:04 PM
Dieselwrencher's Avatar
The 6bt's aren't that heavy. More like 950-1000lbs without accessories but with pump and turbo.
Old Oct 16, 2009 | 12:33 PM
millco's Avatar
I found it!! (Answers to some of our questions about the mighty Cummins!!)
Cummins B Series Brochure
Glad I had been told wrong! My 'conversion' truck was already heavy enough! . . . LOL
Old Oct 17, 2009 | 02:46 AM
47Ford - 1.5Ton's Avatar
You can expect near 800 lbs wet and loaded w/ all accessories on.....
Mine came in at 783lbs I believe when I weight it at work before going to the dyno. (To really see what airbags I needed to run up front)
Fun and easy little motors to work on that will pull a big block like a toy in the torque department........ weight wise I never worried about.... I'm gonna be really tipping the scales no matter what I do.
~Mike
perrya
8
Mar 21, 2015 02:58 AM
Cumminsfreak24
Feb 11, 2015 01:47 PM
Jan 20, 2015 03:01 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
Nov 5, 2014 05:30 PM
