Dodge Diesel Tech Articles All Years of Cummins Tech Talk
Instructional videos on how to "tweak" the VE injection pump,
Old Oct 12, 2009 | 08:15 PM
crossy's son's Avatar
Old Oct 12, 2009 | 09:32 PM
muskrat's Avatar
Well done, man. And welcome to DB
Old Oct 12, 2009 | 10:51 PM
tower_ofpower's Avatar
i do believe i used your video for a base on how to bump my timing; and i ripped the idea of the ratchet strap off of you. good work just a suggestion; if you dont wanna drill the hole larger you can hook it to the mount of the air box. i think this is a little sturdier too. it didnt mess the inner side of your fender up? b/c it took a good bit of pulling to break my IP loose
Old Oct 13, 2009 | 04:31 PM
RSWORDS's Avatar
Awesome Videos Brandon! Good to see you on here buddy!
Old Oct 14, 2009 | 12:00 AM
i was doing bobby's throttle indexing mod and i kinda noticed my pump doesnt automatically return to idle, in fact it doesnt get any spring tension until 1/4-1/2 throttle... i think my governor spring is about as stretched out as pamela anderson and the throttle return springs/ bracket were AWOL... the trucks been in my family since they bought it in 89 and they've never modded anything... infact they've always complained it was nutless from day one
Old Oct 27, 2009 | 09:34 PM
1stGen89's Avatar
thanks for the vid. i just had to replace the fan clutch so i rotatd the fuel pin because i ws bored. i didnt turn the star wheel thing though is that ok? i coudnt remeber how far i thought 1.5 turns but it seemed like alot. i played with the smoke screw but that doesnt do much at all.
Old Oct 29, 2009 | 11:31 AM
smokincummins92's Avatar
Nice vids dude very helpfull!!
Old Oct 30, 2009 | 11:47 AM
Heavy's Avatar
awesome videos man.My question is when you say mildly ground fuel pin what is the best way to go about grinding the fuel pin
Old Oct 31, 2009 | 02:15 PM
seandonato73's Avatar
i took a die grinder to my fuel pin...in the process of getting a set of m&h fuel pins
Hey great video man now i can go bump my timing up an 1/8
Old Oct 31, 2009 | 03:04 PM
muskrat's Avatar
If you're refering to tower ofpower's signiture, you take a grinder and grind the deepest side down to almost nothing, then grab a welder, turn it way too hot, then proceed to burn it clean into two pieces. Sorry, I couldn't resist.
