lock up problems
Old Oct 12, 2009 | 02:37 PM
BAD ASS RAM's Avatar
Default lock up problems
i put a billet convertor in my truck cause my old one was slipping.ever since it has not locked up.it shows a tc lock up circuit and pressure sensor.i changed the tc lock up switch and nothing.a tranny guy i know says that if the seal in the convertor (the one that holds pressure to lock up)is bad it will send codes,is this possoble,would the computer know if something was physically wrong with the convertor?or should i keep changing swutches?
Old Oct 12, 2009 | 02:43 PM
12vcummins96's Avatar
yes it is possible because you will have a pressure loss at the governor pressure solinoid
Old Oct 12, 2009 | 03:09 PM
IS THERE ANY WAY TO TEST IT?HOW CAN I KNOW IF THE SOLENOID IS WORKING,ISN'T THERE SOME WAY OF TESTING VOLTAGE OR MAYBE GROUNDING IT OUT ON THE SOLENOID ITSELF.AND COULD IT BE THE PRESSURE SENSOR,IS THIS A LIKELY CAUSE?
Old Oct 19, 2009 | 09:17 PM
wildbill's Avatar
Updates??
Old Oct 23, 2009 | 10:46 PM
wildbill's Avatar
Closing thread due to inactivity. Thread starter can reopen.
cumminspwr11
12
Oct 17, 2021 03:50 AM
TONYFERLAND
Apr 27, 2015 03:14 PM
Ol Goat
Jan 22, 2015 02:16 AM
Cody Cain
Dec 22, 2014 01:27 PM
Cody Cain
Dec 21, 2014 06:50 PM
