Neighbors are complaining about smoke.
Old Oct 8, 2009 | 02:17 PM
rugerbeast's Avatar
Default Neighbors are complaining about smoke.
I drive a 97 F350 7.3lt. 1000 miles ago I broke down in no where and had to have my High Pressure Oil Pump replaced. I picked up the truck and it ran fine. Now from start up to shut down It's putting out blue white smoke like crazy. It acts and responds like its loading up a couple of cylinders. If I stand on the fuel it will clean out and excelerate about 3000 rpm but goes right back to smokeing and no power as soon as I let off. It has 240,000 miles and to my knowledge is still running the original OEM injectors. Any suggestions?
Old Oct 8, 2009 | 02:18 PM
wildbill's Avatar
I'm thinking a couple bad injectors myself.
Old Oct 8, 2009 | 09:23 PM
gradyc's Avatar
How much oil is it using? It might also be the injector o-rings. It will use a lot of oil if that is it.
Old Oct 9, 2009 | 07:45 AM
rugerbeast's Avatar
Quite a bit, 1 quart per 1000 miles. No noise like engine knocking.
Old Oct 9, 2009 | 10:54 AM
gradyc's Avatar
One quart per thousand is not too far out of line. It might have a little leakage but in this case it sounds like bad injectors is more likely.
Old Oct 9, 2009 | 11:40 AM
12vcummins96's Avatar
Old Oct 10, 2009 | 08:37 PM
wildbill's Avatar
Updates??
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
gagemotors
Jun 9, 2015 04:24 AM
ASarsano
Oct 15, 2014 05:33 AM
