O6 2500 Ram No A/C
Old Oct 6, 2009 | 08:51 PM
surfindieseldude's Avatar
Default O6 2500 Ram No A/C
Hey is anybody out there having trouble with a/c on their dodge. My a/c went out one second cold air next warm. The light on the panel indicates its on, the blower is working but warm air is coming out. I drive between Texas and Florida for construction as you can tell I need a/c. I understand the tipm can go bad. Here's the kick in the a"# the odometer just crept past 36000 miles.
Old Oct 6, 2009 | 09:11 PM
gradyc's Avatar
Have you tried to put power directly to the compressor clutch to see if it gets cold then? The ac clutch is controlled by the ECM so the problem could be with something in the other engine controls. Is your check engine light on when the A.C. is not working? A code check might be helpful.
Old Oct 6, 2009 | 09:32 PM
wildbill's Avatar
Some dealers will still honor the warranty a little past the 36000 mark.
Old Oct 7, 2009 | 04:28 PM
busta's Avatar
check the wiring
ours was going out and the guy went straight under neath and did something with the wiring to the ac and it hasn`t stopped working since but since it is right at 36 000 he went a head and ordered a new compressor for it
just waiting for him to have time to put it on
Old Oct 7, 2009 | 06:41 PM
Hey guys thanks for the replies, nuthing seems to be working yet. Put the gauge on the low side and it was reading 135 psi and I know its only supposed to be in the 45psi range so sh#@
The Comp in this rig has been changed twice and the newest one reflashed the last time i drove in from Florida to Texas with a trailer. The injectors where not opperating correctly
Last edited by surfindieseldude; Oct 7, 2009 at 06:41 PM. Reason: Automerged Doublepost
Old Oct 7, 2009 | 08:47 PM
gradyc's Avatar
135 psi without the compressor running means that you have freon in it. The low side pressure is around 45 to 60 only when the compressor is running. At least it means you probably don't have a leak in the system. You have something electrical wrong not letting the compressor come on.
Old Oct 10, 2009 | 08:35 PM
wildbill's Avatar
Updates??
Old Oct 15, 2009 | 11:34 PM
wildbill's Avatar
Closing down for now. Thread starter can reopen and update.
hoeky22
For Sale
Mar 15, 2015 08:35 PM
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
