retarding timing
Old Oct 6, 2009 | 11:31 AM
12.valve.hauler's Avatar
Default retarding timing
what do i ave to do to get my 215 pump to not retard timing in higher rpms and how much will it cost
Old Oct 6, 2009 | 12:18 PM
12vcummins96's Avatar
the timing should be set it souldnt move have u set your timing
Old Oct 6, 2009 | 01:53 PM
mysterync's Avatar
The 215 Pump Retards at rack travel above 19mm.
At 19MM it retards 3deg and at 21 it retards 4deg IIRC.
Also, If I remember correctly Smokem stated a while back you can make 700RWHP or more with 18MM of rack travel
Old Oct 6, 2009 | 05:33 PM
12valvetater's Avatar
you can make it so that it dont retard the timing it involves replacing the plungers i think with flat tops? ask 94 12valve he has a 913 pump that dont retard the timing i think
Old Oct 6, 2009 | 05:37 PM
Hammer's Avatar
Barrel and plungers,depending on what ones you have installed,could cost anywhere from $700-1000 just themselves and thats not counting the time the pump man spends with your pump on the stand tuning it.Changing them is not a job for the backyard mechanic as once they are done the pump needs to be set and rebalanced....andy
Old Oct 6, 2009 | 06:16 PM
mysterync's Avatar
If the truck is tuned correctly, With the correct parts combination there shouldnt be a need to eliminate the feature. As long as rack travel stays below say 17MM. Is that close to correct andy?
Old Oct 7, 2009 | 11:00 AM
Smokem's Avatar
Timing starts to retard just after 13mm.
Old Oct 7, 2009 | 11:15 AM
so if you advance the timing to 16.5* then the retarding part should make no difference then or do you retard the timing when you have it set? i read before but i cant remember which thread it was on and i tend to forget alot of things
Old Oct 7, 2009 | 12:29 PM
Smokem's Avatar
Let's make this simple, using a starting point of 15° static advance;
13mm - 15°
14mm - 14.5°
15mm - 14°
16mm - 13.5°
17mm - 13°
18mm - 12.5°
19mm - 12°
20mm - 11.5°
21mm - 11°
Old Oct 7, 2009 | 07:59 PM
94 12valve's Avatar
yes I have flat top plungers in mine
