h2 wheels
Old Oct 1, 2009 | 08:25 PM
brk126's Avatar
Default h2 wheels
wanna put h2 wheels on my 07 2500 ram....what do i have to do to make them fit and will they stick out past the body line of the truck?
Old Oct 3, 2009 | 11:48 PM
JTProuhet's Avatar
you have to have the center of the wheels milled out just a smidged to fit over the hubs... there is a little more backspacing than factory dodge wheels.. not much.. also they are 8.5" wide as opposed to 8" I am picking up a set this week for my truck.. I am going to see if my friend can mill them out at work, or i am going to find someone that has a router and just do it myself.. there is a couple guys over on CompD that have done it and have pics...
And actually your factory dodge center caps will also fit, you just have to do a little modification to them.. I am going to trim them up a bit to fit and then probably get 4 C emblems and do the emblem trick to the center caps
Old Oct 4, 2009 | 08:58 PM
brk126's Avatar
thanks...you wouldnt happen to have the exact measurments that need cut
Old Oct 9, 2009 | 03:36 PM
JTProuhet's Avatar
i know that it needs to end up like 4.774"... i just picked up my h2 wheels yesterday and going to just get a router and do it with that and a flush cut bit... there is a little ridge in the hub hole already, and if you use that to let the bearing of the bit to ride on, it will open it up to the right size...
Texas Diesel
Sep 4, 2018 12:24 AM
smokerattlenroll
Mar 30, 2017 05:17 AM
ramrunner01
Mar 18, 2015 09:00 PM
HotRodCrewCab
For Sale
Feb 12, 2015 09:12 AM
Dec 8, 2014 07:10 PM
