which lift pump ?
Old Sep 21, 2009 | 12:34 PM
dodge rodder's Avatar
Default which lift pump ?
is the Raptor lift pump enough for my set up, or do i need to go with the 150 Air Dog i have plans for an Quad. Adrenaline and do away with the zxt+. i have a bd lift pump now and when you stand on it it will go to 6-7 lbs.
Old Sep 21, 2009 | 02:22 PM
SeaDrive's Avatar
The AirDog gives you more filtering above the Raptor (pump only). I have a mild setup so the factory filter setup is fine for me and the Raptor has worked flawlessly since day one. I think it would be enough for you.
Old Sep 21, 2009 | 02:26 PM
Uncle Bubba's Avatar
If you haven't looked at it yet check out the MITUSA belt drive mechanical pump before you make this decision. No electric motor to burn out or have to replace brushes in and is completely adjustable from 3-3000 psi to allow it to be used on any truck no matter what mods it does or does not have.
Old Sep 21, 2009 | 02:31 PM
Wyatt Earp's Avatar
If you want a commercial set up you can also check with Parker / Racor as they make a system of 3, 4 and 5 filters. Granted it isn't cheap but if fuel quality is suspect it is the only way to go in my opinion. Which ever unit decide on know that the ones with the filters are well worth the few extra $$.
Old Sep 21, 2009 | 10:10 PM
The Raptor will work just fine. If you want the best filtration get the Airdog.
Old Sep 22, 2009 | 12:06 PM
i may have to go with the Airdog and do away with the stock filter because i want an adr. bad just cant afford one right now.
thankes for the info every one.
Last edited by dodge rodder; Sep 22, 2009 at 12:07 PM. Reason: Automerged Doublepost
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
