6.2 gmc dies under boost
Old Sep 15, 2009 | 07:36 PM
streetwires's Avatar
Default 6.2 gmc dies under boost
I am having an issue with a 86 GMC 6.2t that cuts out or just shuts down under boost. It seemed to happen more often with no restriction in the exhaust (pipe dumped under cab) than it does with the full exhaust. we turned the fuel up about a quarter turn when installing the turbo so i am wondering if it is a fuel issue (to rich or lean) after it dies it restarts no problem.
Old Sep 15, 2009 | 07:39 PM
Woody35's Avatar
do a injection pump test, slowly rev it up to 2000 rpm and slowly lower it back down to idle
Old Sep 15, 2009 | 07:40 PM
captain_stabbin's Avatar
is it possible that you could have turned the pump down???
Old Sep 16, 2009 | 05:54 PM
I don't think so. i turned the allen screw in the pump 1/4 turn clockwise and with the addition of the turbo, gained a noticeable power increase.
did a slow rev up to 2k and back down and it runs smooth, i do notice it being around 6-8psi boost and under load when it cuts off and dies. with the exhaust turned down under the cab it will hit 11psi boost but it dies more often.
Last edited by streetwires; Sep 16, 2009 at 05:54 PM. Reason: Automerged Doublepost
Old Sep 27, 2009 | 07:35 AM
wildbill's Avatar
Updates??
Old Oct 3, 2009 | 03:25 AM
wildbill's Avatar
Closing down for now. Thread starter can reopen an update.
Jun 5, 2015 01:48 AM
Jan 13, 2015 09:00 PM
DanielC559
Dec 8, 2014 06:20 AM
Oct 18, 2014 10:10 AM
Oct 14, 2014 03:30 PM
