'99 7.3 PSD fuel line replaced, now no start.
Old Sep 7, 2009 | 12:05 PM
rdarkhelmut's Avatar
Default '99 7.3 PSD fuel line replaced, now no start.
i just replaced the fuel lines from the filter housng to the flex lines by the crossmember. i turned the key on & off a few times to refill the filter. it started and ran for a minute or 2 and started smokin and dieseling bad. started back up and still sounded bad. now it won't even smoke or run. i have fuel to the filter, but not sure of where else to check for fuel or what else to check. not sure if and where to bleed any air out of the system.
Old Sep 8, 2009 | 08:11 AM
Deputydog's Avatar
When you turn the key to the "run" position, can you hear your fuel pump?
sounds like its not getting fuel to the engine.
Cavnar
Sep 9, 2015 07:18 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
ninetyoned250
Mar 1, 2015 09:10 PM
moneypitk5
Feb 12, 2015 11:01 AM
