bad vibration between 1500 to 18000 rpms
Old Aug 27, 2009 | 07:49 PM
06black3500megacabcummins's Avatar
Default bad vibration between 1500 to 18000 rpms
My truck vibrates between 1500 to 1800 rpms. anything below that its fine and anything above that its fine. it does it while driving and while not driving. please help!
Old Aug 27, 2009 | 07:52 PM
mysterync's Avatar
Could it be a miss possibly, We'll need more information to be able to help!
Give us some details about the problem and we'll do everything we can to get ya a solution!
Old Aug 27, 2009 | 07:55 PM
wildbill's Avatar
Sounds like an injector issue.
Old Aug 27, 2009 | 07:59 PM
the truck vibrates siting still just reving it, it does it 1st through 6th gear at the same rpms. (1500-1800). feels the same pulling or not
if its an injector problem why would it stop vibrating after 1800 rps? it wouldnt stay the same or get worse?
Last edited by 06black3500megacabcummins; Aug 27, 2009 at 07:59 PM. Reason: Automerged Doublepost
Old Aug 27, 2009 | 08:34 PM
mysterync's Avatar
Not really, It can present it's self in many ways. Are there any codes on the truck. Like i said, There's not enough info here for us to get an idea of whats going on
Old Aug 27, 2009 | 08:39 PM
Whit's Avatar
Site Mascot
twin turbos , big shower heads and a chip will fix it
theres no codes, it ran fine just a few days ago. what kind of info do you need? what do you think about the crankshaft vibration damper?
Old Aug 27, 2009 | 09:21 PM
mysterync's Avatar
Well , Are you seeing any smoke , any unusual noise. The vibration could be hundreds of things, Converter or Pressure plate problems , the Damper.... injectors, a dead cylinder. The list continues. Any information regarding the truck and mod's done to the truck will get us closer to a diagnoses!
Old Aug 27, 2009 | 09:40 PM
the only mod is straight piped that i know of i just bought the truck 4-5 months ago. nothing else apears to be moded. it doesnt smoke at all, doesnt seem to lack any power, theres no unnormal noises or sounds, shift smothly, clutch works great. the truck drives just like normal except for between 1500 to 1800 rpms. thats when the hole truck vibrates or shakes. its bad, feels like bad worped rotors when you jam on the brakes, but it does it while siting still reving the engine, driving in all 6 gears, accelerating, and decelerating.
Old Aug 29, 2009 | 12:09 PM
can anyone else help. PLEASE!!!
