turbo upgrade
Old Aug 24, 2009 | 05:10 PM
03whitechrome's Avatar
Default turbo upgrade
well the turbo i was planing on running everyone said that the exhuast houseing is to big for what im trying to run so im going to try another set up please give me some ideas to work with i was going to run a s475 with a diff exhaust housing but its to big...
Old Aug 24, 2009 | 06:18 PM
II Silver Bullet
Cheetah
Old Aug 24, 2009 | 06:59 PM
2500HeavyDuty's Avatar
have yu tried looking at an s464?
Old Aug 24, 2009 | 07:28 PM
dosnt the s464 have a t6 flange.. i can only run a t4 unless i have somthing custom.. and i dont wanna go into that yeat..
the s475 i was looking at has the specs as listed
High-flow S400 model, with compressor flow over 98 lb/min. Will service 900+HP. Also commonly known as an S475 and S375.
Wheel Dimensions: Compressor: 74.7 mm inducer, 100.8mm exducer, with exclusive Extended Tip Technology. Turbine: 95.5 inducer, 87.9mm exducer. Cast in Inconel 713 for high-temperature operation.
Housing A/R: Compressor .63, with 5.0" hose-type inlet, and v-band-type discharge. Turbine: 1.32, with 'divided' volute, featuring 'T6-style' turbine inlet flange (4.438"x2.75"), and quick-release v-band discharge flange. Cast in ductile iron.
This is the model that's dominating the medium-frame turbocharger market. With 'direct-fit' compatibility with existing 'T-' and 'GT' series units.
i have been told that its to big to run so im not gonna run that turbo anymore im looking into trying to get something like a 4094 or somthing
Last edited by 03whitechrome; Aug 24, 2009 at 07:28 PM. Reason: Automerged Doublepost
Old Aug 24, 2009 | 09:17 PM
you can get them in a T4 flange from forced inductions.
Cdog121
Nov 16, 2015 01:49 PM
n2brk
Feb 21, 2015 09:05 AM
BIGRED12V
16
Jan 3, 2015 07:47 PM
brown2294
Nov 3, 2014 10:09 PM
strokin97
Sep 30, 2014 11:59 PM
