won't run
Old Aug 23, 2009 | 12:45 PM
BMFRACING's Avatar
Default won't run
Hello all, I have an 02 ford psd and it runs for about 3min. and shuts down it starts up again! i changed the cam sensor first, the same problem any clues out there? also i there away to pull codes without scan tool? thanx BMF
Old Aug 23, 2009 | 04:16 PM
gradyc's Avatar
Unfortunately there is no way to read the codes without a scan tool. You might have a dirty fuel filter.
Old Aug 23, 2009 | 04:23 PM
BMFRACING's Avatar
I changed the filter two months back. Its funny because it starts right up runs for a min and shuts off!
Old Aug 23, 2009 | 05:49 PM
gradyc's Avatar
It might be worth hooking up a fuel pressure gauge and watch it when you start it. You might have a fuel pump that is not working all the time. It should have about 60 psi fuel pressure.
Old Aug 26, 2009 | 10:06 PM
BMFRACING's Avatar
thankx will try that.
Old Aug 26, 2009 | 10:11 PM
wildbill's Avatar
Check the oil level in the HPOP.
Old Aug 27, 2009 | 11:01 PM
BMFRACING's Avatar
Today i took the banks 6gun off and the truck ran for an hour! Could it be bad? Whats the best tuner out there? Thankx
Old Sep 10, 2009 | 10:51 AM
stkdram55's Avatar
updates??
vin_diesel
Mar 1, 2016 01:43 PM
Josh923
Sep 10, 2015 11:16 AM
rusmis91
Chevy/GMC Duramax 04.5-05 LLY
Aug 6, 2015 04:44 AM
rick-64
Mar 19, 2015 07:59 PM
wvwelder89
Nov 20, 2014 10:26 AM
