6.5 timing issues
Old Aug 22, 2009 | 06:56 AM
red's Avatar
red
Default 6.5 timing issues
I have rebuilt my original engine replaced the 20 to 1 pistons with 18 to 1 ceramic toped
pistons had no wear on cyls crank or cam runs great problem is I have been running
a mechanical inj pump for years everyone telles me that to set the timing must have
old school timing light. any ideas where to find such an animal?
Old Aug 22, 2009 | 10:55 AM
wildbill's Avatar
Can't use a timing light on a diesel. Need to tilt the pump to the drivers side to advance or the passenger side to retard. Should be 3 nuts that hold the pump to the engine.
Old Aug 22, 2009 | 03:38 PM
dragogt's Avatar
^^ Why? Ive seen it done, at the shop I worked at the lead was clipped to the #1 injector line.
But yeah, you move the injector pump it change it.
Old Aug 22, 2009 | 08:59 PM
Woody35's Avatar
you also need a tech 2 scanner or autoengunity to set the tdco beside turning the pump to complete the timing on a electronic 6.5
Old Aug 23, 2009 | 01:39 PM
red's Avatar
red
this injection system has no connection to yhe computer at all dont think a scanner will
help much but thanks for the input.
I understand turning of the pump to set timing the timing light im' talking about clipped on no 1 injector line sensed the pressure and gave you a signal to set the timing on the first 6.2 and 6.5 why else would they put timing marks on the engine at all.
Old Aug 23, 2009 | 03:03 PM
Woody35's Avatar
on the ds4 they are but i see you switched to a db2 so yes it wont do anything
Old Sep 17, 2009 | 07:55 AM
red's Avatar
red
well folks just wanted to drop a linejust drove 96 GMC crew cab dual on vacation
drove to fla and back over montegal mt in TN. 18 to 1 pistons are the way to go
she ran up the mt 63 mph 12 pounds torbo 950 exaust temp 190 engine temp. I LOVE IT guess I must be pretty close on the timing with the mechanical pump. Drove over 2,300 miles not glitch one. Hope everyone has this much luck with there truck.
Daniel Finney
Oct 22, 2019 01:58 PM
quiksilver1j
Jul 30, 2015 12:41 PM
hockeyguy651
Feb 5, 2015 05:55 PM
Polaris04
Dec 1, 2014 08:27 AM
SMatyac
Nov 15, 2014 07:35 PM
