QUESTION ON COPPER HEAD GASKETS
Old Aug 20, 2009 | 12:57 AM
moseswal's Avatar
Default QUESTION ON COPPER HEAD GASKETS
Sorry for all the simple questions guys, im a newbie to diesels aswell.
I had two steels gaskets fail aleady mainly because i doubled the power and torque on my pick up but , does copper gaskets work on diesels.Does it give a stronger seal compared to steel gaskets.
Old Aug 20, 2009 | 01:06 AM
toy4xchris's Avatar
what all do you have done to the truck?
are you running stock style head bolts?
I know I had a problem with head gaskets I ended up finding out one of my main problems was the threads on the front pass side head bolts are actually so close to the water jacket that it causes it to leak up through them bolt hole and from there it blows the gasket. if you take some teflon pipe thread paste and put it on the bolts it helps some and I have torqued them down a few lbs tighter than stock specs and it helped alot. I hope that helps some I don't know much about the gaskets though. I know a buddy had mentioned some nicer mls gaskets and that they work well.
Old Aug 20, 2009 | 01:28 AM
scrappy's Avatar
the 3rd gens come stock with MLS gaskets.
the 3rd gen gasket will work fine in a 24V. and I think I heard that they will work on a 12v also.
I don't think copper is a good idea, they won't stay sealed on a DD. that and I think a diesel is too hot.
Old Aug 20, 2009 | 01:30 AM
94cummins12v's Avatar
i know they have them cometic head gaskets, they are supposed to be the best thing as far as strength aside form o-rings
Old Aug 20, 2009 | 01:33 AM
moseswal's Avatar
I've also torqed mine tighter that stock specs.Mods: sequential turbos ,bigger intercooler,ceramic coated pistons,75mm powerflow exhast,3.7 crown and pinion
Attached Thumbnails QUESTION ON COPPER HEAD GASKETS-25052009456.jpg   QUESTION ON COPPER HEAD GASKETS-photo-0074.jpg
Old Aug 20, 2009 | 01:34 AM
stkdram55's Avatar
i would try to get the head fire ringed...which i believe is a small really thing copper gasket that circles the cylinder and helps with blow by
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Adam65
Jan 9, 2015 11:50 PM
Oct 31, 2014 08:10 AM
Hardcorefx4
Oct 6, 2014 07:47 PM
