CR ?
Old Aug 18, 2009 | 09:03 PM
Jet A Fuel's Avatar
Default What year dodge trucks are CR fuel injected?
Is the common rail fuel system aftermarket only? or are some cummins powered trucks stock with this type system?
Last edited by Jet A Fuel; Aug 18, 2009 at 09:38 PM. Reason: Needed to add a Question mark
Old Aug 18, 2009 | 09:05 PM
Need clarification - what exactly do you want to know?
Old Aug 18, 2009 | 09:10 PM
Jet A Fuel's Avatar
is the common rail fuel system different than an VP44 driven system?Is it a CP3?
Old Aug 18, 2009 | 09:38 PM
2500HeavyDuty's Avatar
yes alot different, common rail cummins trucks in rams are the 03 and up models
Old Aug 18, 2009 | 09:40 PM
Jet A Fuel's Avatar
Is it better than the VP44 system? Is it posible to upgrade If I buy a used pump and the lines?
Old Aug 18, 2009 | 10:04 PM
CR is a better design than the VP44. It would be easier and cheaper to convert to a P7100 injection pump from a 12V Cummins.
Old Aug 18, 2009 | 10:09 PM
Jet A Fuel's Avatar
Thanks, my truck has 235000 miles i am experiancing some jerking /bucking at rpms above 2100 I am going to check the filter and the lift pump i hope that does it. Thanks again for the info.
Old Aug 18, 2009 | 10:15 PM
Im still a bit lost as to what your asking - are you asking about converting a VP-44 truck to a commonrail?
Yeah, the Commonrail with the CP-3 pump is a much better system and the pumps take a lot more abuse than a VP-44.
But, this would not be an easy or cheap conversion - if it can be done at all.
Old Aug 18, 2009 | 10:19 PM
stkdram55's Avatar
The sheer money it would take to get the computers to work ...would be enough to ster me away from it...
Get a good VP and a good lift pump and when i say good i dont mean a new OEM one...im talking Airdog, FASS, MITUSA belt drive pump...
