turbo injector ??'s
Old Aug 17, 2009 | 02:22 PM
CumminsKid6's Avatar
Default turbo injector ??'s
im planin on gettin 200 to 250 horse injectors and was wanderin would an hx40 be a sufficient turbo to run and get decent power and put a lil smoke away??
Old Aug 17, 2009 | 02:28 PM
mysterync's Avatar
No, While the 40 was a good charger in it's day. It's not enough for a 200+ injector in a 24v. Also , Shaft damage would be a major concern. You would be spooling the charger hard in the first place, and it's not easy to prevent turbo surge on a VP truck. There are items available to help with surge but you could get you a good charger with the amount you would give for a 40 and blow off valve setup!
Old Aug 17, 2009 | 05:20 PM
ben99's Avatar
I'd say you need at least a 62mm with that big of injectors.
Old Aug 17, 2009 | 05:47 PM
Your going to need more than a HX40 or a 62 to work with 200-250hp injectors. Maybe a Silver 62. Do you tow any with your truck?
Old Aug 17, 2009 | 10:08 PM
well. i dont tow with it right know alot. a few things here and there but nothin reall heavy. and i thought it would maybe do ok cause my dads truck has 125 injetors with stock turbo. seein about 52 lbs of boost and gets rid of 75 to 80% of the smoke and its still holdin up for now. nock on wood
Old Aug 17, 2009 | 10:15 PM
mysterync's Avatar
I would be knocking on somthing besides wood. No stock charger will hold 52lbs but a few times. If your seeing 52lbs, you need to check some things out. A factory HX series charger will implode very quickly that high. Also, It's actully loosing alot of power there, Your well out of the efficency of the charger!
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
