#100 PLATE IN STOCK LOC. OR SLID BACK A HAIR
Old Aug 14, 2009 | 11:45 AM
jaybuller's Avatar
Default #100 PLATE IN STOCK LOC. OR SLID BACK A HAIR
alright i have this 100 plate, i want to put it in but dont want to slip my stock clutch. so if i put it in the stock location or mabey even back a hair would this be better than my stock plate, but still not enough to slip my clutch? thanks
Old Aug 14, 2009 | 11:56 AM
Atchley's Avatar
Should be fine. Dont recommend boosted launches though haha
Old Aug 14, 2009 | 02:02 PM
Lil Dog's Avatar
Should be Ok in the stock location. Don't forget to bump the AFC housing ahead a touch too. Then... HOLD ON!!!
Old Aug 14, 2009 | 02:58 PM
jaybuller's Avatar
what does the afc housing forward do? ill try the 100 in the stock location, and tell you guys how it does
Old Aug 14, 2009 | 05:16 PM
Lil Dog's Avatar
Once you start putting in plates and such, you are going to need to get familiar with all the adjustments to get the full value and tune. AFC housing position will affect how you reach the new plate you installed and may restrict it with its internal settings. Loosening the starwheel and also adjusting the zero boost stop screw are all going to be needed to control off the line fuel, top end fuel as well as how hard it comes on.
Old Aug 14, 2009 | 05:42 PM
bowtech's Avatar
lil dog can you tell me how to set my afc. i have a 12 plate slid all the way. What do you mean slide the afc? is that what goes over the fuel plate? what does that do and witch way to move it. and what do i do for more fuel on top?
Old Aug 14, 2009 | 06:13 PM
oglejust's Avatar
the afc is wat u take off to c the plate, the bolt holes r slotted a little bit so u slide it forward and it gives u a little bit. for more fuel on top u can get a gsk and a rack plug
Old Aug 14, 2009 | 06:55 PM
Lil Dog's Avatar
Wow.. Thats a long topic..
Firstly you are going to study the parts you took off and then see how they fit together. If you noticed the AFC foot that is next to the plate, it has a slight taper as you work your way up. 2 things about it.
1.With the housing in the stock position, the AFC foot can only move so far forward under boost full boost. Depending on the model of pump you have, the worst case is the 215 pump, it can take up to 40psi to get the foot to be at full forward travel. Adjusting the star wheel spring pressure is reduced and less boost moves the foot. Also spring kits for the AFC ( I have one) help to make the adjustments softer and allow for more movement of the AFC foot. Also you can find posts on AFC grinding mods for full travel forward.
2.Moving the AFC housing forward moves up the "zero" point of the initial governor travel right off the line. So when you first hit the pedal, how much fuel is administered. This can be stock, no smoke or full forward, clouds of thick black soot. Moving the AFC housing forward requires loosening out of this stop to get the off line fuel under control. Too much and you just flood the engine, too little and its a slug.
When you move the AFC forward you are allowing it to get out of the way of the fuel plate you just purchased and allow the governor to follow the profile on the plate. If you don't allow for that, you are just running on the AFC foot until you get enough boost to get on the plate.
So if you do move your plate forward to the end and don't modify or adjust your AFC housing position, you are not getting the full effect.
Some photos may help..
Here is a cutaway of the system installed. The zero stop is at the far right. Starwheel in the center with the spring against the diaphragm.
Now the relationship between the plate and AFC foot..
You can see here that if the AFC doesn't move farther forward, You don't touch the plate. And if you have a 0 plate, your fuel plate is at the top notch.. Long ways to travel forward without sliding it.
Hope that helps... Best to take some tools and put them on the passenger floor and take day to tune it in. Everyone wants different response.
diesel pap
Mighty Diesel
Jun 26, 2015 10:26 AM
Whitereaper12v
8
Dec 22, 2014 10:22 PM
wyoborn&bred
Nov 25, 2014 06:35 PM
