wiring
Old Aug 10, 2009 | 06:06 PM
torquey's Avatar
Default wiring
anyone got any ideas on what would cause my air con/power windows not to work when i tilt the steering wheel+ i got codes1687&1693.
Old Aug 10, 2009 | 06:25 PM
Jazz's Avatar
It works if you don't tilt it? That doesn't make sense to me. Does it not work in any position of the tilt?
Old Aug 10, 2009 | 06:56 PM
wildbill's Avatar
Sounds like a bad electrical connection in the steering column.
Old Aug 10, 2009 | 07:07 PM
Jazz's Avatar
Yeah, but why the a/c and power windows?
Old Aug 11, 2009 | 10:23 AM
torquey's Avatar
ok guys, took it apart and found a wire pulled out of the connecter,fixed it but left the lights on while replacing a license plate bulb(killed'er good)so i'll charge her up and check my work,thanks guys.
Old Aug 11, 2009 | 10:39 AM
spoolin's Avatar
Probably all runs across the column to the fuse box or something.
Old Aug 11, 2009 | 11:23 AM
We will close this one. You can reopen it if you need/want to.
cumminspwr11
12
Oct 17, 2021 03:50 AM
ofelas
11
Aug 12, 2015 07:23 PM
yzrider250
Diesel Engine Conversions
Aug 10, 2015 11:33 AM
Forks diesel nut
Jul 27, 2015 12:19 PM
Mike H
Nov 25, 2014 03:13 PM
