maybe turbo? maybe wastegate
Old Aug 2, 2009 | 07:29 PM
brandon's Avatar
Default maybe turbo? maybe wastegate
i have a 2006 cummins. it had a cracked exhaust manifold when i bought it. just a quick fix, but when i fixed it i noticed the turbo wasnt as free as id like and there was what looked like oil or soot in the face of the turbo. and the fins had small dings in them. i noted the problems but decided to finish the manifold replacement and put the turbo back in and keep an eye on it. but when i took it for a test drive, when you drive it like youve got your grandma it runs fine, but when you mash the gas like your trying to pass someone it falls on its *** andthe second it falls theres a slight whistle like the wastegate unloading. as long as the trucks running at 1/4 throttle theres nothing wrong, but as soon as the turbo starts to spool its just loses it. maybe its the wastegate, hopefully not the turbo. any help would be appreciate it.
Old Aug 2, 2009 | 07:37 PM
jasonfriedlin's Avatar
Do you have a boost gauge on it and if so is it reading anything at all at quarter throttle. Is there a lot of black smoke out of the exhaust?
Old Aug 2, 2009 | 07:43 PM
wildbill's Avatar
If there are small dings in on the compressor side, chances are the turbine end is worse.
Old Aug 4, 2009 | 09:17 PM
wildbill's Avatar
Any updates??
Old Aug 4, 2009 | 09:21 PM
sidekick's Avatar
check the boost and also check the wastegate to make sure it is holding closed
Old Aug 19, 2009 | 03:49 AM
wildbill's Avatar
Closing due to members last activity on 8-3-09.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
