running p1211 code
Old Jul 30, 2009 | 06:09 PM
brando's Avatar
Default running p1211 code
I have a 2001 Ford F350 7.3 litre diesel with cold air intake, 4in turbo back exhaust, and an Edge Evolution programmer with 83500 miles and when I gotta get on it it will run p1211 code. Also, I am not getting the mileage I was told I would get out of this engine expected around 19 am getting around 14. What is going on with this truck? I am very frustrated and would be very greatful for any help that I receive. Thanks.
Old Jul 30, 2009 | 10:41 PM
sirthomas's Avatar
what setting are you running the programmer on?
Old Jul 31, 2009 | 01:12 PM
brando's Avatar
Number 3 extreme.
Old Jul 31, 2009 | 01:58 PM
CSIPSD's Avatar
P1211 is an ICP code, you will get that code when running higher HP tunes due to the HPOP (high pressure oil pump) not keeping up. There is nothing you can do about it really without going to a dual or big oil set up. With a better tuner you may find you have more HP and less ICP (injector control pressure) called out for, so you would not get the code as much.
As far as your milage goes, 90% of it is due to your heavy right foot. If your running around on the extream tune, I would imagine that at every red light your blowing a little smoke... Smoke means bad milage more or less. Extream settings are most times the best for MPG, but you have to learn to drive with a very light foot.
Old Jul 31, 2009 | 08:47 PM
brando's Avatar
I trully don't drive like a wild man. I only get on it when I have to, and when I do get on it that's when I get the smoke. Do you recommend a different programmer(better one)?
Old Aug 1, 2009 | 12:49 PM
Kyle_KleinSS's Avatar
Dp tuner or TW. Everyone will tell you edge is junk on your trans anyway.
Old Aug 2, 2009 | 02:42 PM
blk99's Avatar
for starters, call Swamps and get a chip from them...
and i agree with CSI, plus, the lower ICP can also be a big factor in your hurting MPG...without the enough HPO the fuel does not atomize as well (AKA more smoke) which in turn, as CSI said, give you less mileage.... should really consider upgrading your HPOP with a Terminator or Stealth setup...
dwmeehan
Sep 6, 2015 04:20 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
carid
Jan 12, 2015 04:32 AM
