Tachometer that stops and starts
Old Jul 26, 2009 | 10:27 PM
Gabriel J. Eder's Avatar
Default Tachometer that stops and starts
I have an 02 with an automatic transmission (5.9). The tach works on and off when ever I start and drive my truck. There isn't a pattern when the tach will do this. I had a code of P1693. Any idea's? Possible loose wire, is the computor going out?
Old Jul 26, 2009 | 10:29 PM
wildbill's Avatar
I want to say the crank position sensor is going out. The P1693 is a companion code, meaning another code set.
Old Jul 26, 2009 | 10:34 PM
stkdram55's Avatar
yeah its either the crank or cam position sensor i can never keep track...when mine did this the code was for the crank sensor and it fixed but now its doing it again, its behind the starter
Old Aug 4, 2009 | 09:10 PM
wildbill's Avatar
Any updates??
