93' chevy 3500 cummins swap
Old Jul 14, 2009 | 12:49 AM
fuelinblood84's Avatar
Default 93' chevy 3500 cummins swap
Hey guys I've got a perfectly good 3500 chevy with a blown 6.5l turbo and a the factory five speed. I am wondering if I can hook a 12v cummins to the factory manual trans, or if I need an adapter where can I get one. I'm almost sure that my trans. is an NV4500?
Old Jul 14, 2009 | 07:59 AM
FastCR's Avatar
yep you can do it and it is an nv4500. You need a cummins bell housing (I think, I'm actually not even sure on that part) and a cummins input shaft and bearing retainer thing. Then dodge clutch and hydraulics and your set
Old Jul 15, 2009 | 09:56 PM
cool man thanks do you know how much all stuff might be. The only thing I have is the engine, turbo, and balancer. no trans but it had manual behind it.
Old Jul 15, 2009 | 11:59 PM
FastCR's Avatar
for drivetrain you need a cummins input shaft and a cummins bellhousing, both interchange between any nv4500s. If you want bolt on parts, Auto World is the place to go. Fabrication can be and has been done many ways. Just a lot of time with a tape measure.
I'm assuming its a 4x4, I think you might need a different front driveline because the stocker will be too short.
Basically, there's a lot of different ways to do it. The autoworld stuff will basically bolt up and work without too much fiddling on your part.
Another tidbit is a lot of people put a body lift on for more room to work with, but it has been done without. I can't help much with clearances because I stripped the front of my truck to the frame rails and designed the suspension and engine mounting together. There are a few people that have done the swap on here, and once you go through it you know your setup inside and out. If you need a "How did you make this part work?" there are plenty of people to help you out and have a straightforward answer.
DieselDan370
Aug 23, 2016 02:24 PM
STDiesel59
Jul 11, 2015 10:09 AM
jeremiah1
Jun 18, 2015 05:01 PM
ReckONE
Feb 25, 2015 09:41 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
