Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
2000 engine in a 97
Old Jul 13, 2009 | 10:48 PM
Branch's Avatar
Default 2000 engine in a 97
i put a 2000 engine in a 1997 f250. i still have to put a fuel pump on it. im trying to figure out how to make my old wiring harness work on my newer engine. most of the wires on the old harness will hook up to the new engine but there are more plugs and wires on the newer harness. and im not sure how to hook my wastegate actuator up on my new turbo with my old wiring. is there a way to do this? or would i be better off trying to find a free flowing exhaust housing? any suggestions about the turbo? and i think i wanna keep the split shot injectors. will my old wiring harness work for the newer injectors if i swap the uvc harnesses and the valve covers and gaskets from the old to the new?
if anyone has any ideas im listening. im about done withe the truck if i can just get the injection and wastegate hooked up and running
Old Jul 13, 2009 | 11:07 PM
MossBack's Avatar
sounds like your heading in the right direction. Id like to know as some day i may be down the same road
if you need anything technical as to your 97 i've got the whole Ford service manual. Let me know. and ill look it up
Old Jul 14, 2009 | 12:44 AM
CSIPSD's Avatar
You need to take the entire wire harness off the blown up motor and swap it to the new motor. Everything else will be fine.
Old Jul 14, 2009 | 01:07 AM
Superstroker10's Avatar
they should all have the same (IMPORTANT) senor connectors.
Old Jul 14, 2009 | 11:15 AM
Branch's Avatar
well the old motors actually still running. i had the truck torn all apart and the motor out and i found a newer motor out of a 2000. i guess il try to get everything hooked up and see if shel run. iv talked to several people who say il have to get a custom chip to run the newer injectors with the old computers
Old Jul 14, 2009 | 03:28 PM
ya you will. or you can just have the pcm flashed for it. but i would go with the new injectors and get a chip (dp tuner,swamps) etc..
Old Jul 14, 2009 | 03:49 PM
CSIPSD's Avatar
The single shot programing will run the splits fine, there will be some qurks but nothing you cant tune around when you get a chip later.
That differance alone will not keep it from running.
Old Jul 14, 2009 | 07:14 PM
Branch's Avatar
do i need to put the old camshaft position sensor on the new engine too?
Old Jul 14, 2009 | 11:46 PM
if its black and is old HELL YES run that one.
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Nov 16, 2014 05:14 AM
Oct 30, 2014 08:10 AM
