Need 6.2 fix advice
Old Jul 11, 2009 | 04:11 PM
wadeclinton's Avatar
Default Need 6.2 fix advice
Long winded reader beware. I burned up the rod bearings on cyl 3&4, oil pump sized. I went and found a 6.5 turbo engine suposedly running. As luck would have it it was done. No compression cylinders 1&6. So wasted $400. A friend gave me 82 red block short block. Acording to him he got it from a guy who pulled it at 100000 miles to replace it with a new crate engine with a banks turbo. What I want to do is take my 83 plus heads from the bad rod bearing engine. ( I looked at the heads they look fine). Then use the 93 6.5l turbo and serpentine acessories to finish it off. I have Plans to use ARP head studs. And a diesel services stud girdle to help cope with the new pressures of the turbo. My question is can I use the block as is no new rings/bearings and be ok? I don't have the cash for a $600 re ring kit. Also I inspected the rings and bearings they look just fine no abnormal wear or anything. I can also see faint cross hatches in the cylinders. Any input would be great.
Clint
Old Jul 12, 2009 | 06:09 PM
Woody35's Avatar
first beware of the girdles for 6.5. they dont really do much. if you really want a girdle make or get a custom one that actually does its job. i know its a pain and by the looks of it you dont have a ton of money so ditch the girdle and get new rings.
with new rings it should last a bit longer. but after saying that you got to remember that your putting a turbo on a engine not meant for it so it wont last as long as a regular naturally aspirated 6.2 or turbo 6.5. but with some tender loving care and good maintenance it should last a long time.
since its a 82 you need coarse thread injectors and i doubt the those injectors will be able to fully keep up with the turbo so be ready for a little loss of power. i would also turn up your pump while your at it
Old Jul 22, 2009 | 10:45 PM
Well thanks for the input. I have a few questions. Would the 6.5 L injectors be better in the 83 plus heads I'm going to use? Is it a good idea to put new rings on old Bearings? I cant really afford to do the whole thing. The stud girdle is for a 6.2 Block are these any better than the 6.5L ones? What does one that really works look like? Who makes it ect ? I had plans to turn the pump up and I have the gauges to keep tabs on it.
Thanks for the info
Old Jul 24, 2009 | 09:40 AM
Woody35's Avatar
yes it would because the 6.2 ones cant flow as much
Sorry not sure on that
that stud girdle wasnt meant for a turbocharged 6.2 it was for longevetity on a abused naturally aspirated 6.2. im not saying girdles dont work on these engines im saying the girdles available are not very good. if you get a custom girdle that is desighned right it will work very well
Very good idea
Thanks for the info
my notes are in red
Old Jul 25, 2009 | 07:06 PM
Copy thanks for the advise. Wish I didn't have to do this on the cheap. It kills me to not have everything perfect but cash is the kicker. If money wasn't an issue I'd do a cummins swap and go like gangbusters.
Spaky6.0mudder
Aug 3, 2015 08:54 PM
jedder21
Mar 7, 2015 09:47 PM
twm011
Feb 24, 2015 09:11 AM
Caveman94
Dec 8, 2014 12:21 PM
