*HELP* 6.0 will turnover, no start
Old Jul 5, 2009 | 11:23 PM
Mikes Truck Repair's Avatar
Angry *HELP* 6.0 will turnover, no start
Ok first off it had a cod p2285 Injector ctrl pressure sensor circ low i replaced my icp and ipr ok the code went awway still no crank i have the batterys on a charger so couldnt be batteries all my pressures are good but when i turn the key over no rattle in the fuel injectors is it the idm or what else could it be
Old Jul 5, 2009 | 11:37 PM
stkdram55's Avatar
what the mileage on the oil, injectors might not be firing properly if the oil is too old
Old Jul 5, 2009 | 11:43 PM
wildbill's Avatar
*wildbill moved*
Not sure on this end bud.
Old Jul 6, 2009 | 09:40 AM
RSWORDS's Avatar
Check your oil first, one of teh Ford guys will be in in a min to get you straight beyond that
Old Jul 11, 2009 | 10:48 PM
gradyc's Avatar
If the cps is bad the ecm doesn't know the engine is turning and won't send signals to the injector module to fire the injectors and a bad cps doesn't always set a code. Maybe not the problem but worth checking.
Old Jul 15, 2009 | 08:40 PM
wildbill's Avatar
What's the good word??
Old Jul 19, 2009 | 02:05 AM
Big Angry Hillbilly's Avatar
PM me your phone number Mike's truck repair and I will get you fixed up.
Old Jul 23, 2009 | 05:30 PM
wildbill's Avatar
Any updates??
Old Jul 25, 2009 | 09:10 PM
gdixon's Avatar
do you know what your cranking oil pressure is
Cavnar
Sep 9, 2015 07:18 PM
emilio2496
Jun 29, 2015 03:00 AM
Accubuck
May 7, 2015 04:46 PM
cjgregory
Mar 31, 2015 01:45 PM
thumperf350
Jan 8, 2015 12:55 AM
