Tow mirrors.. electrical problem
Old Jun 20, 2009 | 12:08 PM
OverPressured's Avatar
Default Tow mirrors.. electrical problem
Well i put on my set of kool vue towing mirrors today on my 98 12v. Hooked up all of my electronics. Put the door panels back on and buttoned everything up. Hit the adjustment lever for the mirrors and nothing They are power and heated. Then after driving it down the road i realize I have no radio. My radio is dead. Also I realized I have no interrier lights at all. The harnesses on the mirrors looked to line up great. I cant really think of anythgin thats causing this. My new mirrors wont move, not at all. I checked all of my fuses and couldnt find anything. Anyone know if I shorted out something ? And how to possibly fix it? Thanks
Old Jun 20, 2009 | 12:15 PM
RSWORDS's Avatar
How did you check the fuses? Just looked at them? You need to do a continuity check on them. I have seen more then one fuse look fine but be bad.
I would get the old test light out and start checking conections. Start at the mirrors and start working backwards to see were you lose power. Same thing with the radio.
Old Jun 21, 2009 | 10:55 PM
Thanks.. gonna try that tomorrow. I heard that I may have pinched my wires while installing them when i tighten the bolts that support the mirrors. But i dont see how that would effect my radio or dome lights.. they wont work now.
Found the problem.. Blew my IOD fuse in the cab fuse panel. How do I fix it? Replaced it with another 10 amp but blew it again. Should i bump it up to a little bigger fuse?
Last edited by OverPressured; Jun 21, 2009 at 10:55 PM. Reason: Automerged Doublepost
Old Jun 21, 2009 | 11:09 PM
vlado's Avatar
no you have short to ground somwhere most likely
Old Jun 23, 2009 | 12:54 AM
I replaced the fuse with a 15amp. Everything works but my mirrors only turn certain directions. Like the passenger wont go up and down the but the driver side wont go to the right.. So im guessing I have a cut wire now?
Everything works!! Turns out i pinched a wire even after the 2nd time of putting them on. Everything works good on a 10a now! Thanks guys
Last edited by OverPressured; Jun 23, 2009 at 12:54 AM. Reason: Automerged Doublepost
Old Jun 23, 2009 | 01:01 AM
Excellent - closing the thread
burndiesel
10
Feb 7, 2023 01:15 AM
KTWillys
6.7 Liter Dodge Cummins 2013+
9
Mar 5, 2016 06:41 PM
Boostaddiction
May 4, 2015 06:33 AM
Dadslb7
Dec 9, 2014 11:05 PM
