6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
Do I "need" a pyro?
Old Jun 10, 2009 | 10:09 PM
thirdstreettito's Avatar
Default Do I "need" a pyro?
I want to turn the pump up on my 84, I know I should get a pyro. I dont have the money for a pyro/mount/wiring etc. My truck averages 140*F in 95*F weather, so I wouldn't think the EGT's would get too high, and I dont tow much.
Old Jun 10, 2009 | 10:30 PM
ltr450's Avatar
i would put one on it to be safe and the old chevys run hot any way
Old Jun 11, 2009 | 08:42 PM
Ah well. Who has the cheapest pyro and thermocouple etc?
Old Jun 11, 2009 | 09:03 PM
RSWORDS's Avatar
Yes...
For the best service/price hit up some of our sponcors by putting a post here.
Price Quote - Request A Price - Diesel Bombers
Old Jun 11, 2009 | 09:31 PM
FastCR's Avatar
is it turbo'd? If not I'd say eff it.
Old Jun 11, 2009 | 10:56 PM
RS, I forgot all about that! No turbo. What is eff?
Old Jun 11, 2009 | 11:02 PM
FastCR's Avatar
I meant eff as representing a word. like the verb possibly used to describe an encounter with a lady friend.
You don't need one. The pyro is usually used to check pre turbo exhaust temps to stop from melting the turbo. On higher HP apps it also has to be monitored so you don't melt the pistons. but the 6.2 pump won't flow enough for you to have to worry about that.
Old Jun 12, 2009 | 06:51 AM
I have heard that if a 6.2 gets too hot with a turned up pump you can warp the heads.
Old Jun 12, 2009 | 01:55 PM
FastCR's Avatar
You''d be more concerned about engine temp than egt. If you want to be careful with it, get a good autometer (or some other brand) temp gauge and watch it. Your right that you can warp the heads, and on the IDI motors it isn't hard to do, because the heads create so much heat.
Old Jun 12, 2009 | 09:03 PM
Well the engine runs very cool. I've always been told to watch the EGT's, so I figured I should. Where would I put the probe? I have true duals. Also, would it be ok to dyno the truck 2 times with the pump turned up a little?
