03 Dodge CR
Old Jun 2, 2009 | 08:03 PM
elio's Avatar
Default 03 Dodge CR
Please Help!!!
problem, original injectors went bad had them changed . ordered online from Industrial Injection & Turbo service ,inc. out of Salt lake city. had them changed . Truck is now making noises in one of the cylinders. does anyone know , could it be one of the injectors are bad? How can I find out.
Old Jun 2, 2009 | 08:18 PM
Red_Rattler's Avatar
High Tech Redneck
Who installed the injectors?
Last edited by MRaynor; Jun 3, 2009 at 09:59 AM. Reason: Started new thread for OP
Old Jun 3, 2009 | 10:00 AM
MRaynor's Avatar
I moved this here for better exposure and maybe get you some help faster.
Old Jun 3, 2009 | 12:13 PM
High Tech Redneck
Thanks Mike
Old Jun 3, 2009 | 02:49 PM
dixierebel0213's Avatar
i have replaced loads of injectors in the 5.9 is a knocking type noise? if so injector my be hanging and not getting its preignition causing excessive knock pull valve cover and disconnect each injector until knock disappears, disconnect with engine off, once you find out which move injector to another cylinder then repeat steps and see if the knock moves if it does replace injector, if it dont make sure high pressure connector is tight and not deformed
Old Jun 3, 2009 | 05:15 PM
06 DIESEL's Avatar
Check the wires for a tight connection and make sure that they are all on the correct way also.
Old Jun 4, 2009 | 12:21 PM
High Tech Redneck
I'm thinkin this will be a one hit wonder thread.....
Old Jun 18, 2009 | 09:48 PM
wildbill's Avatar
Closing this thread due to a one time post. Last post was on 06-02-2009. Thread starter can reopen if need be.
May 7, 2015 02:50 PM
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
