Kubota 3 cylinder industrial engine conversion
Old Jun 2, 2009 | 08:15 PM
brixspeed's Avatar
Default Kubota 3 cylinder industrial engine conversion
I have a Kubota 3 cylinder 762 cc industrial diesel engine that i want to put into a suzuki super carry cargo. I read somewhere here that an industrial engine is different to the road engine. That the industrial engine is load dependent and the road engine is accelerator dependent. My question is, can I make an industrial engine into a road engine? Can I make the industrial engine behave like a road engine? Thankful for anybody who can help me with my problem.
Old Jun 2, 2009 | 08:18 PM
DB Admin's Avatar
Banned
/me moved to proper forum .
Old Jun 2, 2009 | 08:26 PM
74dj5d's Avatar
yes you can it just feels weird on the foot
Old Jun 2, 2009 | 08:32 PM
Whit's Avatar
Site Mascot
check this out bro
https://www.dieselbombers.com/diesel...nger-swap.html
Old Jun 2, 2009 | 09:16 PM
jakebilt's Avatar
If you have read my previous posts on the Kubota Ranger swap you know pretty much everything I do. About the only thing I can add is that governors built for a generator application do not work very well. Not personal experience but I have heard that many times. The industrial governor works great. Just takes a little getting used to. Good luck with your project.
Old Jun 3, 2009 | 12:05 AM
brixspeed's Avatar
Thanks for the info. I was hoping to I could change the way the governor work the way a road engine would, without drastically changing any parts.
Old Jun 3, 2009 | 07:16 AM
Whit's Avatar
Site Mascot
On a genst motor the cam is set to run @ a given RPM , will have to be changed and the lifters may be different as well.
The injectors will need swaped
piston bowls will most likely be different
The exhaust manifold is prolly different
good possibility the fuel injection pump and the governor are different too
research this very well b4 ya commit
Old Jun 3, 2009 | 10:46 AM
solarwarp's Avatar
I wish I was smart enough to take on a conversion project like this...
Jakebilt has a sweet little Ranger.
burndiesel
10
Feb 7, 2023 01:15 AM
metal_miner
Dec 23, 2014 11:40 PM
learningdiesel
Dec 17, 2014 11:06 AM
Oct 30, 2014 08:10 AM
Rx7man
Oct 15, 2014 04:00 AM
