Yet another blown up sub 500hp 7.3...
Old Jun 1, 2009 | 05:36 PM
CSIPSD's Avatar
Default Yet another blown up sub 500hp 7.3...
Not sure where to go now... So many issues, so little money.
Block is fine, heads are fine...
Pistons are cracked, ALL the pistons are cracked...
Ate a main bearing, not sure what damage may or may not be there...
David may or may not help fix it due to the broken main bolt.
Very frustrated with the whole SUB 500hp cracked pistons with less then 30k on the motor. No high sustained EGT's, three dyno pulls, never made it to the pulls with it...
My stock block with 120k of water injection, stage 1's, stage 2's and hybrids... Pistons look great.
Discuss? There are a few things that changed on this motor from my stocker, lets see where this takes us.
BTW, that oil above... has less then 30 miles on it!
Me having my way with the Great Big B****... GBB is what Chelsea (wife) calls her...
Cracked pistons...
Boxed up and ready to go...
Old Jun 1, 2009 | 05:39 PM
Red_Rattler's Avatar
High Tech Redneck
Sucks to hear that man.... Time for a Cummins?
Whit's Avatar
Site Mascot
eye yi yi........carnage fer sure, high HP got ya
have you developed a gameplan yet?
Old Jun 1, 2009 | 05:43 PM
CSIPSD's Avatar
Motor is going back to DI to get worked over, coated pistons with the bowls cut most likely... Then throw her back in with some differant tuning and hope for 500-525 on fuel.
The injectors are out now getting worked over, new nozzles and just a good check up.
The turbo is going out shortly, check up and all...
and the HPOP is going out as well.
I am too broke to get it really up there right now. O ya, the Cummins was VERY close to going in this time!
Old Jun 1, 2009 | 05:47 PM
CSIPSD's Avatar
Hell it was only a few months ago from this...
And before that it was another tranny...
UGH... LOL
Old Jun 1, 2009 | 06:22 PM
High Tech Redneck
When it rains...... It pours....
It also could be that JD green..... The IH felt betrayed
Old Jun 1, 2009 | 06:39 PM
CSIPSD's Avatar
I told him when it comes back to make it black... or Gray... but not a hint of green!
Old Jun 3, 2009 | 12:03 AM
CL-14's Avatar
man im sorry to hear about your problem hope it works out for ya. you should paint it red
Old Jun 3, 2009 | 12:10 AM
2500HeavyDuty's Avatar
paint it ford blue!!
were you runnign dual hpops with it. how much boost pressure where you running in the motor.
you have pics of the other 7 pistons
Old Jun 3, 2009 | 01:32 AM
stkdram55's Avatar
thats crazy man, there has to be some way to make them things stand up to 500+ HP
