Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
Jacobs E Brake troubles
Old May 31, 2009 | 11:34 AM
oneaviator's Avatar
Default Jacobs E Brake troubles
I have an 8.3 cummins with a Jacobs E brake in my motorhome. I can not tell a difference when I engage the E brake or turn it off when decelerating. At Idel you can hear it close the exhaust and you can see it working. Does a spring wear out? Anyone know what the problem might be.
Thanks
Oneaviator
Old May 31, 2009 | 06:23 PM
coyropin's Avatar
you need to get them adjusted you can make it so that it will throw you into the windshield get you overhead checked out how many miles on it??
Old May 31, 2009 | 08:49 PM
oneaviator's Avatar
It has 65,000 miles. Not to sound stupid, but what is the overhead?
Thanks for the response
Old May 31, 2009 | 09:05 PM
coyropin's Avatar
thats your vavles, Intake Exhaust but at 65k you should be ok, is the exaust brake in your exhaust pipe, or is it in the vavle cover
Old Jun 1, 2009 | 01:51 PM
oneaviator's Avatar
It is in the exhaust pipe, about 3 feet after the turbo
Old Jun 1, 2009 | 10:36 PM
74dj5d's Avatar
if you can make it stroke watch to see how far it moves. then pull the linkage off and see if it was all the way closed. if not fix it. if it was then something is dead. sorry i cant be more help but i have only been in one truck with one and it sucked.
Old Jun 1, 2009 | 10:41 PM
Red_Rattler's Avatar
High Tech Redneck
How old is the brake? Could be a weak spring/diaphram actuator. Could be just out of adjustment. The air lines going to it are in good shape, no marks or chaffs?
Old Jul 12, 2009 | 04:43 PM
Superstroker10's Avatar
silinoid could be shot which activates the brake
weatherby
Aug 31, 2015 08:04 PM
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
Ryguy
Mar 14, 2015 08:45 PM
yams
Nov 29, 2014 09:25 PM
