turbo upgrade?
Old May 11, 2009 | 12:33 PM
c0zgrove's Avatar
Default turbo upgrade?
hey guys i gotta question does anyone know the size of the factory turbo on a 6.7 and would it be an upgrade from my hx35 my dad is thinking of upgrading his and i figured if it was an upgrade for me why not take the free turbo
thanks guys
Old May 11, 2009 | 04:13 PM
sstockton's Avatar
They decent sized. I'm really not sure what it takes to get the Variable geometry turbine system to work on a different truck either.
Sean
Old May 11, 2009 | 04:33 PM
dieseldude03's Avatar
That may be a tall order. Like stated above, they are a variable geometry turbo, as well as being electronically controlled and water-cooled.
Old May 24, 2009 | 01:36 AM
XLR8R's Avatar
That BOMB is pretty tough to build...
even though the compressor & turbine are very similiar to the HE351W we're so familiar with from the 5.9L CR, and the relatively large (~20cm) exhaust housing closes down to less than 10cm for good spool-up and lower high-RPM drive pressure - the VGT actuator would need a stand-alone computer with a driver circuit capable of controlling the 3-phase brushless DC motor.
The water cooling plumbing is easy enough to install.
I'd advise your Dad to use the existing turbo as the secondary in a twinset - that way he keeps all of it's electronic advantages (such as exhaust braking & WG control) while adding CFM capacity for plenty of extra fuel... besides, primary air is cheaper!
Cdog121
Nov 16, 2015 01:49 PM
n2brk
Feb 21, 2015 09:05 AM
BIGRED12V
16
Jan 3, 2015 07:47 PM
brown2294
Nov 3, 2014 10:09 PM
strokin97
Sep 30, 2014 11:59 PM
