fuel running back to tank
Old May 7, 2009 | 03:17 PM
Diesel Dummie's Avatar
Question fuel running back to tank
hey guys, just getting ready to replace the lift pump in my '96 ram 1 ton, and was wondering when i do, will this also stop the fuel from running back to the tank after the truck sits for a few days. Is there a check valve in the lp, or in the ip... thanks all
Old May 14, 2009 | 08:28 AM
MRaynor's Avatar
Anybody have any ideas on this?
Old Jun 7, 2009 | 12:26 PM
MRaynor's Avatar
Any updates?
Old Jun 7, 2009 | 12:31 PM
Uncle Bubba's Avatar
This is generally caused by the internal pressure regulator being worn out or a bad ground in the pump wiring that doesn't allow the regulator to close when you shut the truck down, so ya either way if you replace it it should fix the problem.
If you listen close just as soon as you hear the truck shut off, if you hear fuel rushing back into the tank that's a bad ground, if you don't then the bypass is just worn out.
Old Jun 18, 2009 | 10:30 PM
wildbill's Avatar
Last Activity: 05-21-2009 Can reopen the thread if need be to update.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
