possible fuel pump
Old May 3, 2009 | 05:17 PM
mark350's Avatar
Default possible fuel pump
2004 f350 6.o while driving it will lose power sputter then shut off also fuel pump on frame making loud whinning noise.Both filters have been changed.
Old May 3, 2009 | 06:31 PM
robammerman's Avatar
What do you have to do to get it to restart?
Old May 3, 2009 | 08:47 PM
mark350's Avatar
I dont know if I need to but if I wait till fuel pump quits running after I turn key on it almost always starts back up
Old May 4, 2009 | 10:57 AM
twinpeaksdiesel's Avatar
It sounds like it could be either a bad pump or the fuel line could be sucking in air. The easiest way to check this is to apply air pressure to your tank and check for leaks. If the pump is bad and you want a better than factory pump, FASS is in the testing phase of a powerstroke direct replacement pump.
Last edited by MRaynor; May 14, 2009 at 08:37 AM. Reason: No advertising if you are not a sponsor.
Old May 14, 2009 | 08:32 AM
MRaynor's Avatar
Any updates?
Old Jun 7, 2009 | 12:21 PM
MRaynor's Avatar
Since there have been no updates in so long, I'm going to assume that the problem is fixed and am closing this thread. The thread can be re opened if needed.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
bud0994
9
Jun 8, 2015 06:15 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Gm3500
May 7, 2015 11:01 AM
