PLEASE CHANGE YOUR OWN OIL...
Old May 3, 2009 | 03:57 PM
99_f250's Avatar
Default PLEASE CHANGE YOUR OWN OIL...
this happened to me awhile back..figured out this moron only put 5 quarts in.... and for some reason i just didnt check the oil level... but this happens when u have 5 quarts of oil in a psd
http://videos.streetfire.net/video/99-f250-not-wanting-to-on_183908.htm
http://videos.streetfire.net/video/99-f250-not-wanting-to-on_183912.htm
http://videos.streetfire.net/video/99-f250-not-wanting-to-on_183913.htm
THE TRUCKS FINE NOW...JUST GLAD IT WENT INTO LIKE SAFE MODE AND WOULDNT RUN OR ID BE OUT A MOTOR..BUY MINES FINE...ALREADY PUT AROUND 10,000 MILES ON IT SINCE.....all i had to do was add oil ....
o yea another thing about doing your own oil change..i took it to a shop over here in dallas and i saw two kids tugging real hard on my oil filter and after that would leak like crazy...even after i told them be careful cause i dont want u to mess it up and also change the oil drain plug seal...they told me the seals fine and then thats when i saw them tugging on the oil filter...and now it leaks...so every single day it lets out about a cd size puddle everywere i go so im always adding out now... until i get enough money to get an oil change ill have to keep doin this
Old May 3, 2009 | 04:16 PM
89silverbullet's Avatar
that is why i dont trust the idiots that are trained in a class room and told by a computer what to do. sucks man good to hear your turbo didnt get fried.
Old May 3, 2009 | 04:21 PM
99_f250's Avatar
yea i was so excited when i just added oil and drove it that it was fine ah man....a feeling i never wanna feel again when it wasnt starting
Old May 3, 2009 | 10:21 PM
Kyle_KleinSS's Avatar
good thing we do our own oil changes!
Old May 3, 2009 | 11:10 PM
99_f250's Avatar
i do my own oil changes now..
Old May 4, 2009 | 12:56 AM
coyropin's Avatar
yeah my friend took his to a oil lube shop and they forgot to put oil in the motor he had a 7.3 ford, went to court and lost cuz he went in the next day, they told him that he could have done it to get a new motor
Old May 4, 2009 | 01:07 AM
94cummins12v's Avatar
is there a reason you kept running it like that? or were you not aware at the time?
Old May 4, 2009 | 12:54 PM
joey7319's Avatar
with all that cranking, I suprised you didnt fry the starter.
Old May 5, 2009 | 11:16 AM
Blue01F250's Avatar
Duramax Virgin
if a PSD doesn't have enough oil, it won't run, period... not really a safe mode, it just can't run because there isn't enough oil to create enough pressure to fire the injectores = no run...
The only places that have ever changed the oil on my truck is the dealership or me - just sucks getting rid of 4 gallons of oil every time..
and to the OP - why not just get a new oil filter and after letting your truck sit overnight or for a few hours to let the oil drain back to the pan (most anyway) and just change your filter. Then add oil if you need to... Simple fix rather than dumping oil everywhere... Also might get under there and make sure the filter is still tight against the seal.. it might have backed off some with the trucks vibrations if if wasn't on tight...
Old May 5, 2009 | 01:27 PM
sidekick's Avatar
good luck on that glad wasent anymore damage that that
also check to make sure it wasent double sealed some people dont know about checking to make sure the old seal came off before installing the new filter
