04.5-05 LLY Performance Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines Related To Performance And Longevity
water pump replacement
Old Apr 28, 2009 | 09:54 PM
bowtieBrian's Avatar
Default water pump replacement
Hey everyone. I'm looking for some information/tips/tricks on repalcing the water pump. I saw a thread on here a while back about replacing one, but of course when you need it, you can never find it! In particular I'm looking for feedback on pulling the balancer - do I need a puller? how hard is it to get the bolt loose? etc. Any advice/input will be greatly appreciated!
Old Apr 28, 2009 | 09:57 PM
94cummins12v's Avatar
what is it on
Old Apr 28, 2009 | 10:07 PM
2004 Chevy Silverado 3500 D-max
Old Apr 29, 2009 | 01:09 AM
2500HeavyDuty's Avatar
you dont need a puller for the balencer, you can slide it off.
the bolt on there is a 36mm 12pt socket and need a cheater on there. i pretty much covered al the bad stuff on there. you can make the job easier by pulling the fan pulley bracket, there's 5 or 6 14mm bolts holding it on and a deep socket is needed to do that and its a little hard to pull off but its just glued to the block with foam for some reason.
https://www.dieselbombers.com/durama...ement-diy.html
Old May 16, 2009 | 12:23 PM
DazedandConfused's Avatar
How many miles did you guys have on yours before they needed replaced? Did they start leaking on you or what? Were is the weap hole at on these? Mine is leaking but not sure if it is the pump or a hose.
Old May 16, 2009 | 01:07 PM
you can see the weep hole if you look at the pump from the bottom ur gonna have to remove the skid plate to see it.
mine went at 130k
Old May 16, 2009 | 01:15 PM
Yeah I need to pull my skid plate. I can see it running down the lower hose from the top. She has 250K on her so if I replace it and the next one makes it that far I'll be happy.
Old Jul 10, 2009 | 10:01 AM
dirtymax35's Avatar
Mine has 140k on it and I am replacing mine this weekend. Coolant was running pretty good out of the weep hole.
Old Dec 2, 2010 | 11:50 PM
adrianglock's Avatar
My Water Pump Pulley broke down before 140k, had to settle for some surplus parts from nowhere temporarily - got it fixed though and working perfectly.
HeavyChevy95
Dec 21, 2016 10:36 PM
klein444
Mar 8, 2015 08:19 AM
moneypitk5
Feb 12, 2015 11:01 AM
Lawrence D. Sanders Sr
Dec 16, 2014 11:52 PM
mpcampers
Dec 4, 2014 08:24 PM
