rear brakes
Old Apr 18, 2009 | 02:30 PM
Redsmokincummins's Avatar
Exclamation rear brakes
i got my rear brakes done, they seemed to work proplerly. took my wife yesterday to the parents in sask. the right rear wheel heated up badly. we made it there in one peice. i was thinking that the parking brake is sticking or my brakes are dragging on that side. i need to know how the brakes are adjusted, or what to check so i can get back home tm, thanks mike
Old Apr 18, 2009 | 02:44 PM
stkdram55's Avatar
there should be a little opening in the back side of the brake, towards the bottom...its hard to explain...but in there is a little wheel and a tab...to release the brakes more you need to push the tab in and turn the wheel...its a bitch i aint gonna lie..
Old Apr 18, 2009 | 02:48 PM
Default rear brakes
ok, which way does the star wheel turn?
Old Apr 18, 2009 | 02:50 PM
stkdram55's Avatar
it will turn both ways, with the tab not pushed in it will only turn one way and that is to tighten it so you would want to turn it the other way to loosen it
Old Apr 18, 2009 | 03:10 PM
Check rear brakes
ok kool thanks man much apprecaited. hope this will work.
thanks, mike.
Old Apr 19, 2009 | 12:54 PM
Default brakes
i did back off the brake and it seems alot better. the drum was getting warm, so i think i will back it off little more and see hwat it does.
Old Apr 20, 2009 | 08:29 PM
wildbill's Avatar
Any luck??
Old May 1, 2009 | 02:25 AM
wildbill's Avatar
Any updates??
Old May 14, 2009 | 08:52 AM
MRaynor's Avatar
Since no updates in a long time, I'm going to assume this is a fixed problem and am closing the thread. If need be, this thread can be reopened.
Machinist
Jun 23, 2015 06:57 AM
Radioking1777
Jun 9, 2015 04:13 AM
Jun 8, 2015 07:10 AM
thatdude38
May 9, 2015 12:21 PM
kryz9903
May 4, 2015 05:00 AM
