06 Ford lack of power hard start
Old Apr 14, 2009 | 04:44 PM
hunter47's Avatar
Default 06 Ford lack of power hard start
Have a 06 powerstroke. Have serious power issues. I just changed the frame rail fuel pump. Due lack of fuel getting to the top fuel bowl. That worked for that issue but know I am having more problems truck would not start and I also had NO power once I got her started. I am getting pc2290 ICP Injector control pressure to low. I was told it might be the hpop. Anyone have any ideas. How would I found out exactly what it is. The truck is out of warrenty I am on my own for this one. If it is a hpop do they make a after market one or is it best to go straight to ford to get one.
Old Apr 15, 2009 | 12:15 PM
diesel_tallent88's Avatar
Default 6.0
Id pull the valve covers and check the hpo tubes coming from the block to the oil rail there prone to blow orings usually if the pump go its gone it won't start also pull the ipr and make sure the screens still on it good luck
Old Apr 20, 2009 | 08:20 PM
wildbill's Avatar
I can't help much, but other than agree with Diesel talent.
Old Apr 21, 2009 | 07:33 AM
hunter47's Avatar
Thanks guys I think I might have to take this one to the garage. I can not figure it out and do not what to start guessing and put parts on that do not work.
Dec 10, 2014 08:10 AM
