bosch ve pump rebuilding
Old Apr 12, 2009 | 08:02 PM
my dodge diesel's Avatar
Default bosch ve pump rebuilding
Hi every one, i need help on this one. I have a 1992 dodge d250 with the 5.9 cummins, i just pulled the injection pump apart to replace leaking seals. After reassembling and reinstalling pump and bled out air, the truck will not start. My question that i have is when reassembling the pump, does the lugs and the pin on the pumping plate have to be a certain position. Im thinking that this plate can be installed 180 degrees off, which i believe is causing it to inject fuel at the wrong time. Does this sound right, please help
Old Apr 12, 2009 | 08:09 PM
RSWORDS's Avatar
Read through here and see if it helps.
https://www.dieselbombers.com/5-9l-r...ree-temps.html
Old Apr 20, 2009 | 08:10 PM
wildbill's Avatar
Any updates??
Old May 1, 2009 | 02:13 AM
wildbill's Avatar
closing due to a one time post
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
moneypitk5
Feb 12, 2015 11:01 AM
greenbomb
Jan 23, 2015 10:36 PM
