Construction Equipment Discussion of Diesels Used for Construction - Bull Dozer's , Back Hoes , Skid Steers , Track Hoes , Dump Trucks
Bobcat 773 Makin' Oil
Old Apr 9, 2009 | 09:58 PM
7.3 Cowboy's Avatar
Default Bobcat 773 Makin' Oil
We have a Bobcat 773 skid loader that is making oil and losin' hydraulic oil. I notcied the hydraulic oil level was low so i filled it up then checked decided to check the engine oil and the oil covered 90% of the dipstick. SO i thought that the hydraulic oil was leaking into the engine and getting mixed in with the oil. I called the mechanic at the Bobcat dealer and he said there was no way that, that could be happening. The machine needed some other things done to it so I took it up to the dealer and he replaced some seals. Has anyone out there had this or a similar problem?
Old Apr 9, 2009 | 10:14 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i suppose it would be possible if seal was leaking on hyl pump where it is mounted on eng.
Old Apr 9, 2009 | 10:16 PM
00' Quad Cab's Avatar
I know on some equipment (bellhousing driven pumps) if you loose the nose seal in a pump it will make trans./ torque fluid, can't remember how the pump setup is on the Bobkitty's.
Old Apr 10, 2009 | 11:26 AM
7.3 Cowboy's Avatar
That is what I was thinking Dieselpap.
Old Apr 10, 2009 | 07:09 PM
cumminscontrol's Avatar
but if its a gear driven pump and splined in to the engine it wont get into it like that, it would just dump the oil out if the seals are blown..thats kind of weird. i dnt see how the hyd oil is gettin in2 the engine oil unless it could be passin through the cooler somehow. but then again, they are not connected anywhere. not to my knowledge..i know all the Case and CAT equipment that i have worked on aint like that.
Old Apr 10, 2009 | 09:25 PM
7.3 Cowboy's Avatar
I was thinin it had to be gettin in there via the cooler
Old Apr 10, 2009 | 11:22 PM
thats where i would check first...cause those pumps are or at least should be splined like they are on most equipment.
Old Apr 11, 2009 | 08:58 PM
7.3 Cowboy's Avatar
The bobcat mechanic said he replaced some bad seals so we'll see if it fixes it.
Old Apr 14, 2009 | 08:16 AM
gwhammy's Avatar
That machine drives the pump with a belt, no way for oil transfer. It almost sounds like an injection problem and you might be getting diesel in the motor oil. I've been on these machines all my working life and can't see getting hydraulic in the motor. Those kubotas are almost bullet proof motors, smell the motor oil and see how thin it is.
Old Jun 6, 2009 | 08:43 PM
landman873's Avatar
Its diesel i bet you. I had a problem on an 873 one time.
