04.5-05 LLY Performance Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines Related To Performance And Longevity
more fuel
Old Apr 4, 2009 | 11:16 PM
b_r_a_d_79's Avatar
Default more fuel
i want more fuel but i dont want to spend all that money on dual cp3. is there a cheaper way to get more fuel?
Old Apr 5, 2009 | 05:40 PM
2500HeavyDuty's Avatar
you can mod the fca and gear pump on the cp3
also adding a lift pump would help too
Old Apr 5, 2009 | 06:57 PM
b_r_a_d_79's Avatar
i have a carter lift pump
Old Apr 5, 2009 | 07:42 PM
have you had your cp3 modded?
Old Apr 5, 2009 | 10:11 PM
b_r_a_d_79's Avatar
no do you know who could do it?
Old Apr 5, 2009 | 11:13 PM
https://www.dieselbombers.com/durama...-yourself.html
Old Apr 5, 2009 | 11:38 PM
b_r_a_d_79's Avatar
is it a kit and is it hard?
Old Apr 5, 2009 | 11:43 PM
You have to get to the fca first and pull it out (note that the write up is on a lb7 motor, but lly is very similar)
https://www.dieselbombers.com/lb7-bo...fca-k-fpr.html
and then pull it apart and modify it. it helps out with holding a bit more rail pressure. some people swap in a lbz fca cause they flow more but it can cause high rp at idle. but that can be tuned out with efi.
you got to be real clean and careful not to scratch anything in the fca. the plunger inside of it needs to move freely in the fca.
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Gm3500
May 7, 2015 11:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
