need help with pump in tank conversion on 99
Old Mar 31, 2009 | 04:50 PM
nitro's Avatar
Default need help with pump in tank conversion on 99
hey yall , my sender went after my 3rd lift pump on the block and i bought a sender/pump in tank thingy do and just got the harness from dodge
does anyone have the instuctions for the conversions (blue wire black stripe)
can i run both pumps at the same time
or can i run fuel through the block mounted lift pump
funds are tight so not able to buy a fancy racing pump
any help would be appreciated
Old Mar 31, 2009 | 04:58 PM
Dont waste your time and hard earned money sticking that pump in your tank. The intank pumps do not provide adequate pressure and coolong for your VP-44. Take the works back to the dealer and do this.
If money is tight, get a Vulcan performance big line kit and put a Holly Blue or OEM Carter pump on your framerail and isstall 1/2" lines and eliminate the banjo bolts. if you install this right, you can upgrade to a better lift pump later on when funds permit.
http://www.vulcanperformance.com/Dra...p/vpps9804.htm
Old Mar 31, 2009 | 05:03 PM
nitro's Avatar
i got the sender/pump on ebay for 25 bucks and i need the sender and housing (my old style broke where the screws hold the bottom to the top
Old Apr 4, 2009 | 10:51 AM
wildbill's Avatar
Any luck??
Old Apr 4, 2009 | 07:21 PM
Whit's Avatar
Site Mascot
Old Apr 20, 2009 | 08:00 PM
wildbill's Avatar
Thread starter can reopen the thread or start a new one.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Andrew1995
Wanted To Buy (WTB) - Used
Feb 25, 2015 03:44 PM
moneypitk5
Feb 12, 2015 11:01 AM
