Swap a 04.5 5.9 Cummins for a first or second gen.
Old Mar 30, 2009 | 03:59 AM
atchisontim's Avatar
Default Swap a 04.5 5.9 Cummins for a first or second gen.
Guy's I need your help; would like to swap my 04.5 for a first or second gen 5.9 mechanical
"cheap to work on " I have had the 04 engine rebuilt but they messed on the hone job will not start due to low compresson just a thought
Would like some guru's to let me now what all it would take for this swap
Old Mar 30, 2009 | 06:27 AM
LOGANSTANFORTH's Avatar
is there blowby in the crank case???? cause its hard to mess a hone job up that bad, ive seen cylinders not even honed and they hold compression just fine......850 horsepower gas pulling truck engine......you might want to have a shop look at it before you write the engine off.....
Old Mar 30, 2009 | 08:27 PM
I did have a shop look at it Texas power and diesel informed me that it wouldn't hold enough compression to start ; they said it would build to about 200 psi while turning over. I'm not sure I've about had all I can stand when it comes to this engine. I have a compresson tester, guess I should check it to make sure they are not trying to hose me on it
Old Mar 31, 2009 | 10:29 PM
Dieselwrencher's Avatar
If it is having problems starting then it sounds like what they are telling you could be correct. Maybe the guys that honed it honed it too far and the rings have too much gap and there is too much piston clearance now. It isn't hard to over hone if you do not pay attention to detail. Most professional machine shops will bore the cylinder to about .004" less than the desired bore size and hone it to the desired bore size. On the 1st gen swap, it is going to take a lot of little stuff to get everything to work right and honestly you can find a used engine cheaper and it will be a lot faster to get the truck back up and running again.
Bowtie_Cummins
5.9L 12V Performance
Aug 7, 2015 12:08 PM
ryank 199
May 14, 2015 06:41 PM
dezeldoc
For Sale
Feb 2, 2015 04:21 PM
ajpt6.9
Dec 4, 2014 12:06 PM
78F250Cummins
Wanted To Buy (WTB) - Used
Nov 9, 2014 01:12 AM
