#11 fuel plate
Old Mar 29, 2009 | 01:20 PM
brich6600's Avatar
Default #11 fuel plate
I have a 96 cummins. I just installed a 11 plate, afc all the way ahead, plate stock setting, afc all the way ahead. And kit came with restricted waste fitting. I really don't see much difference from stock. I have a stock trans also, but can I have more, or would I be pushing the trans? Move the 11 plate a little forward? Help, thanks
Old Mar 29, 2009 | 01:58 PM
Coco2992's Avatar
auto tranny? i have the same and a guy told me i could go a #6 just watch your gauges
Old Mar 30, 2009 | 08:32 PM
heins's Avatar
one of these days if you r messin around with it, take the plate completely out and see how you like that..if not i would shove that plate all the way forward f i was you. you should see a differance
Old Mar 30, 2009 | 10:04 PM
Coco2992's Avatar
yeah but running it without can cause some serious promblems
Old Mar 30, 2009 | 10:56 PM
djwhonda92's Avatar
i have a 96' w/ a #100 fuel plate all the way forward and my starwheel fully forward and my stock tranny is starting to give out after just 2 weeks.
Old Mar 30, 2009 | 11:16 PM
Coco2992's Avatar
yeah thats a bit you're pushing but im sure you could go get it worked on a bit to handle it
Old Mar 30, 2009 | 11:30 PM
xzaq103's Avatar
FormerVendor
Only trans damage Running plate less will not hurt a thing except your trans. However you need to mod your AFC and a rack plug to take advantage of it. And to much rack travel isnt great for a 215 pump. They run better with a stock plug.
5 speed or Auto? The #11 is my favorite plate for a mild truck. At least in a 215 pump. You should be noticing a deference. What's your boost pressure?
Old Mar 31, 2009 | 03:57 AM
brich6600's Avatar
No gauges, just running the plate for mods and a 4 inch exhaust. Plate came with restricted waste gate fitting. Thats all, stock tranny, stock plate location.
Old Mar 31, 2009 | 06:58 AM
Coco2992's Avatar
get gauges!!!!
Old Mar 31, 2009 | 10:00 AM
xzaq103's Avatar
FormerVendor
get gauges!!!!
X2
I would guess your trans isnt holding it. However without a gauge for boost it could just be a boost leak.
