in know this has been done before
Old Mar 28, 2009 | 08:03 PM
dukeboy_318's Avatar
Default in know this has been done before
let me start off by saying that im not a ford person, however my fiancee has asked me to buy an f250 and put a cummins into it. how hard would this be to do and what all do i need, is there a kit? thanks
Old Mar 28, 2009 | 08:05 PM
Captain Call's Avatar
Ask Squatch on here. He has a real nice 05 with a CR in it.
Old Mar 28, 2009 | 08:25 PM
midnite><og's Avatar
destroked.com
Old Mar 29, 2009 | 05:18 PM
i lookced at destroked.com, bout the only thing id get from them is the motor mounts. im gonna get a 90s era ford f250 4x4 gasser and do the swap, the entire drivetrain will be dodge/cummins, ive decided to stick with an nv4500 and mount that to the motor and then get an adaptor plate and mount the NP203 transfer case that i already have to it. motor wise, im looking at a 12 valve, mostly likely a p-pump motor from 94-98, i may consider a VE considering that my power goal is somewhere around 350-400 though id rather have the p-pump. i may swap a dana 70/80 in eventually, not sure on that yet. ive priced it to be way less then what destroked says it can be done at, they say 10k to 15k total, im looking at maybe 3800 to 4200 in parts total, local junkyard has several 12 vlavers under 2 grand with about 600 for the tranny. clutch stuff will make up the rest of it.
Old Mar 29, 2009 | 05:57 PM
Bandit One's Avatar
Glad to see you got your cummins going. All I can say is my buddies put a powerstroke in a same year ford f250 gasser and it took them two weeks, 400 dollars in beer, lots of blood sweat and tears. This was in a heated shop with a full snapon setup, air, etc. I know that it is easier now with all the kits and everything else but come on bro. Think of something else to spend your money on.
Old Mar 29, 2009 | 08:12 PM
HAYMAFIA's Avatar
instead of using the adapter plate use a divorced transfer case be easier and cheaper
Old Mar 30, 2009 | 09:56 AM
kazairl's Avatar
My personal opinion.
I would probably buy a late 80's or early 90's 250 or SRW 350. I prefer crew cabs but that is my PO. I would get one with a 460 or diesel. IDK what axles they had in the back but the front is a Dana 60 (w Kingpins depending on year). If you get the heavier duty one I wouldn't worry about the axles. They will probably hold up.
If you want a 5-speed you might just look into getting an adapter for the zf-5. The only problem I have found with them is the aluminum tailshaft housing has a tendency to crack from the weight of the transfer case(sometimes not always. Our 86 6.9 has been going on 15 years on its current one) Also the case is all aluminum fyi. I don't know how they hold up for power. But they shift nice (better than my dads 97 Dodge that likes to grind 3rd) and they are easy to speed shift
I'd stay with the same transfer case it comes with. just to make things easier.
As for which year cummins, I think whichever one you can pick up cheap will be good enough. A VE pump will get you to your goal. A P-pump definetly will. Besides you can always swap a P-pump onto a VE later if you feel like it.
Old Mar 30, 2009 | 10:18 AM
yeah im looking for an early 90s 460 4x4 or even a heavy duty 351w. as for spending money on something, i know theres better things to spend money on, but this does seem kinda fun and itd be something that id enjoy. im pretty much at the stopping point for my cummins currently and the fiancee's dakota is a POS and shes never had anything that wasnt a POS and this way she gets a vehicle she likes and gets to pick out how she wants it to look. call me stupid but its an idea
Old Mar 30, 2009 | 12:25 PM
kazairl's Avatar
I for one think it is a sweet idea. I keep thinking I should swap a 4bt in my 88 bronco. Just haven't gotten it done yet.
Old Mar 30, 2009 | 12:51 PM
im not a ford fan, but i think itd be neat. my fiancee and i were looking at getting an 02 or newer jeep grand cherokee but as we both like driving trucks and wanst something dependable, thats why im considering the VE series motors, that and i wouldnt have to worry bout an intercooler, though eventually, id probably get one.
