6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
turbo swap
Old Mar 20, 2009 | 04:29 PM
6.5coalroller's Avatar
Default turbo swap
I'm just wondering if i could swap a different turbo into my truck i've got a 95 6.5. I was wondering if it would really be worth the money and how much power it could make. I've heard you cant do anything unless you swap different pistons in to lower the compression so i figured i might have to spend lots of $$$ i jus wanna get some smoke rollin and roast the tires .
Old Mar 21, 2009 | 01:47 PM
Woody35's Avatar
they have A Team Turbos that are very popular for the 6.5 or you could swap in a HX-35 from a cummins, that is also a popular option. i would start with new marine injectors or a programmer from Heath, SS Diesel, or kennedy diesel for some real power
Old Mar 21, 2009 | 02:44 PM
I've been doing my research and i think i may do the hx 35 swap. I've got some questions tho. First what intercooler should I use? How do i control the wastegate on this turbo and how much boost will a 6.5 take with the 18:1 compression pistons?
Old Mar 23, 2009 | 05:18 AM
_Mitcho_'s Avatar
hey guys
im actually going to do the HX 35w swap too, there is alot of size difference between the stock turbo and the hx35w. im also running a front mount, its a decent size ill put a pic up tomorrow of it. im running 15 psi through my motor everything is stock besides the front mount and 4" turbo back exhaust and it chirps 2nds with 22's haha i get a few funny looks!
Mitch
Old Mar 23, 2009 | 08:10 AM
ya i would imagine try havin an 8 inch stack I get ppl all the time that roll down there window and stick there head out to look at it
Old Mar 28, 2009 | 01:09 PM
Woody35's Avatar
6.5's usually are good running 16-17 PSI Max. the 18-1 compression pistons will really help putting more boost in the engine. 6.5 isnt a engine that runs a lot of boost so if you really want to push it get some ARP studs and some heavy duty gaskets. that will insure you wont blow your heads off then engine
Old Apr 16, 2009 | 02:18 PM
hereismylife's Avatar
Get a chip and you will see a big difference. Yes there are about 5 different turbos that will work great.
Old May 12, 2009 | 12:25 PM
Turbine Doc's Avatar
I asked RSWORDS if it was okay to post a link, we concluded it was okay to post it; were it not for the volume of material involved I'd post the meat and taters of it, and start a new thread here, this is probably the most viewed post in all 6.5 forums out there: 16,300 views at current count.
Above was made mention of the ATT or A Team turbo, me and a buddy decided to go out on a limb and try out a Mitsubishi TD07-22A it worked so well my buddy found a vendor that could duplicate it, details of it are here: Replacement turbo - DieselTowingResource.com
I have most miles on one out there, I commute 1000 miles about every other weekend, so have about 20K so far on mine, my range running mostly 2100-2300 rpm, has gone from 375 miles on a 26 gal tank, to 445 miles packed full to empty (I know this as I ran out of fuel this morning at 445 miles)
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
swelbe
Apr 7, 2015 01:08 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
