Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
diesel fuel!
Old Mar 14, 2009 | 01:18 AM
loudmouth338's Avatar
Default diesel fuel!
I would like to know what is differant about diesel fuel other then less sulfur? The new fuel seems to black smoke less. I would like to know if there is anything I can add to my fuel to get the black smoke back?
Old Mar 14, 2009 | 04:48 AM
wildbill's Avatar
WILDBILL moved here
I don't believe is what's added, but more how it's added??
Old Mar 18, 2009 | 12:40 PM
Freek's Avatar
The new ultra low sulfer fuel is less lubercating and harder on your engine I have heard that lucas fuel add. helps
get back some smoke and better lubes upper cylnders also improve milage i was thinking about trying some my self the guy said to double recomended mix on your first two tank fulls
Old Mar 18, 2009 | 01:00 PM
Heath's Avatar
Authorized Amsoil Dealer
It's a good idea to add something for lubricity. Some use 2 cycle oil...not sure if that adds any smoke or not?? Never done it.
A lot of the fuel additives actually help to reduce smoke by getting a more efficient burn.
Old Mar 18, 2009 | 11:34 PM
onlydiesel88's Avatar
if u use off road diesel will make ur truck smoke more. it is not legel to run on road but its good 4 ur motor
Old Mar 18, 2009 | 11:36 PM
94cummins12v's Avatar
no died wont make it smoke more. why do you want smoke? less smoke and more boost is better
Old Mar 18, 2009 | 11:50 PM
2500HeavyDuty's Avatar
more boost up untill a certain point, then ur just going beyond what the turbo can flow efficiently. but more air the better
Old Mar 18, 2009 | 11:51 PM
well if you want to be technical yes i was just stating a point
Old Mar 20, 2009 | 05:38 PM
Woody35's Avatar
also the ULSD has a higher temp of gelling which doesnt really matter anymore at least for the next 8 months. but add two stroke or another fuel additive to lube your engine better and you really dont need more smoke because your just wasting fuel
Old Mar 25, 2009 | 11:34 AM
Freek's Avatar
get a dp tuner -smoke and injectors
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
moneypitk5
Feb 12, 2015 11:01 AM
12thman
Jan 20, 2015 03:22 PM
Dec 2, 2014 03:10 AM
